how can we tell if Router has buil tin CSU/DSU in it.
mahesh18
Level 6
Level 6
Hi all,
How can we tell if Router has buil tin CSU/DSU in it.
Mahesh
The part numbers that you want to check on are:
2 of WIC-1DSU-T1-V2 (which does have the integrated CSU/DSU)
and maybe VWIC2-2MFT-T1/E1
CCO is http://www.cisco.com
Rick
Rick
12 Replies 12
Richard Burts
mahesh
There are a couple of ways that you can go at the question of how to tell if the router has a built in CSU/DSU. Perhaps the easiest is to look at the connector on the serial card. If the connector is an RJ45 (like Ethernet) then the card has built in CSU/DSU. If the connector is the smart serial connector or the 60 pin connector then it uses an external CSU/DSU.
Or you could do the command show diag. This will identify the type of card in the router. Then you could look on CCO for information about that card and whether it has built in CSU/DSU or not.
Rick
Rick
Hi rick ,
thanks for reply i did sh diag and got lot of information like output is
sh diag
Slot 1:
Ethernet Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time 12w5d ago
EEPROM contents at hardware discovery:
Hardware revision 1.14 Board revision A0
Serial number 16402685 Part number 73-1556-08
FRU Part Number PA-4E=
Test history 0xE RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 02 01 0E 00 FA 48 FD 49 06 14 08 0E 00 00 00
0x10: 50 00 00 00 00 03 24 00 FF FF FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF
Slot 2:
BRI (S/T) Port adapter, 8 ports
Hardware revision 1.1 Board revision A0
Serial number 31909312 Part number 73-2194-03
FRU Part Number PA-8B-S/T=
Test history 0x0 RMA number 00-00-00
0x00: 01 3E 01 01 01 E6 E5 C0 49 08 92 03 00 00 00 00
0x10: 50 00 00 00 05 02 24 00 FF FF FF FF FF FF FF FF
Slot 3:
Mx serial (X.21) Port adapter, 8 ports
Hardware revision 1.13 Board revision A0
Serial number 4468224 Part number 73-1582-05
FRU Part Number PA-8T-X21=
Test history 0x7 RMA number 07-61-80
0x00: 01 0E 01 0D 00 44 2E 00 49 06 2E 05 07 07 3D 50
0x10: 50 00 00 00 97 03 26 00 FF FF FF FF FF FF FF FF
Slot 4:
IMA WAN E1 Port adapter, 8 ports
Hardware revision 1.0 Board revision B0
Serial number 27105153 Part number 73-3611-02
FRU Part Number PA-IMA-E1=
Test history 0xB RMA number 12-33-73
FF FF FF
Slot 5:
ATM WAN E3+ Port adapter, 1 port
Hardware Revision : 1.0
PCB Serial Number : JAE063605E3
Part Number : 73-8194-01
Board Revision : A0
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : PA-A6-E3=
Top Assy. Part Number : 800-21768-01
CLEI Code :
EEPROM format version 4
FF FF FF FF FF FF
Slot 6:
Hardware revision 1.14 Board revision B0
Serial number 21900453 Part number 73-1582-06
Test history 0x10 RMA number 02-24-91
what shoul di look in this output?
Mahesh
You are interested in the FRU part number eg.
in slot 1
in slot 2
etc..
Attached is a link to a pdf on 7200 cards which yOu may find useful.
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_white_paper0900aecd8023dee3.pdf
You can also do individual searches on Cisco site for each of the part numbers for further details.
Jon
Hi jon,
i have this router
Cisco 3825 (revision 1.0) with 225280K/36864K bytes of memory.
Processor board ID FCZ1005718S
2 Gigabit Ethernet interfaces
4 Serial interfaces
2 Serial(sync/async) interfaces
2 Channelized E1/PRI ports
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
also i did
sh diag
Slot 0:
C3825 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 8 ports
Port adapter insertion time unknown
Onboard VPN : FW ver01100200
PCB Serial Number : FOC10024K4P
Top Assy. Part Number : 800-23087-01
Board Revision : A0
Deviation Number : 81879
Fab Version : 06
RMA History : 00
Processor type : 61
Hardware date code : 20060117
Chassis Serial Number : FCZ1005718S
Chassis MAC Address : 0016.c79a.e4b0
MAC Address block size : 32
CLEI Code : IPMEY10BRA
Product (FRU) Number : CISCO3825
Part Number : 73-4021-06
Version Identifier : V01
0x00: 04 FF C1 8B 46 4F 43 31 30 30 32 34 4B 34 50 40
0x10: 04 2A 41 01 00 C0 46 03 20 00 5A 2F 01 42 41 30
0x20: 88 00 01 3F D7 02 06 03 00 81 00 00 00 00 04 00
0x30: 09 61 83 01 32 17 D5 C2 8B 46 43 5A 31 30 30 35
0x40: 37 31 38 53 C3 06 00 16 C7 9A E4 B0 43 00 20 C6
0x50: 8A 49 50 4D 45 59 31 30 42 52 41 CB 8F 43 49 53
0x60: 43 4F 33 38 32 35 20 20 20 20 20 20 82 49 0F B5
0x70: 06 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
Serial 2T (12in1)
Serial number 34641521 Part number 800-03181-02
FRU Part Number WIC-2T=
Connector type PCI
0x20: 01 12 01 00 02 10 96 71 50 0C 6D 02 00 00 00 00
0x30: 58 00 00 00 06 02 15 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
E1 (2 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision D0
Serial number 34567976 Part number 800-04479-03
FRU Part Number VWIC-2MFT-E1=
Connector type PCI
0x20: 01 23 01 00 02 0F 77 28 50 11 7F 03 00 00 00 00
0x30: 68 00 00 00 06 01 09 00 FF FF FF FF FF FF FF FF
AIM Module in slot: 0
PCB Serial Number : FOC09504VXZ
Top Assy. Part Number : 800-24799-01
Board Revision : D0
Fab Version : 03
RMA History : 00
CLEI Code : CNP5FFNAAA
Product (FRU) Number : AIM-VPN/EPII-PLUS
Version Identifier : NA
49 2D 50 4C 55 53 89
so should i lkko for FRU in one of these slots????????
Hi rick,
Can we user sh ver command to check if router has
built in CSUor not?
I have also so many CSU and DSU's in my network. Actually i have to remove all the CSU & DSU's is there any other product or any other router is available so i can terminate my all link on that box and remove all the CSU & DSU's.
Thanks in Advace,
Jerry
Jerry
If I am understanding correctly you have multiple routers in your network and there are many external CSU/DSUs in your network. And you want to replace the external CSU/DSUs with internal CSU/DSUs. There are certainly many routers that will support serial cards with internal CSU/DSUs.
Without knowing more about the layout of your network and knowing what routers you currently deploy we can not tell how many of those routers might support internal CSU/DSU if you replace the serial card and how many routers you would need to replace to get routers that would support internal CSU/DSU.
Rick
Rick
mahesh
From your show version, here are your interfaces:
4 Serial interfaces
This does not provide any insight about whether the CSU/DSU is internal or external.
I started to go through the output of show diag and comment on the card types:
WIC Slot 0:
WIC Slot 1:
and then I realized that in response to my post you posted the output of show diag from one router and in response to a post from Jon that you posted output from show diag on a different router. That makes explaining things more difficult.
If you take the card identifies (VWIC-2MFT-E1=) you should be able to find references on CCO that will tell whether it has internal CSU/DSU or external.
Rick
Rick
Hi Rick
i have this router that has two internal
CSU.here is info for router
Cisco 2821 (2 Gigabit Ethernet interfaces
2 Serial interfaces
2 ATM interfaces
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
1 ATM/Voice AIM
memory.
62720K bytes of ATA CompactFlash (Read/Write)
her eis output from sh diag
h diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Onboard VPN : v2.2.0
PCB Serial Number : FOC11014NXT
Top Assy. Part Number : 800-26921-02
Board Revision : A0
Fab Version : 03
RMA History : 00
Processor type : 87
Hardware date code : 20070107
Chassis Serial Number : FTX1103A0H9
Chassis MAC Address : 0019.30a6.d8c0
CLEI Code : COM3D00BRA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-04
Version Identifier : V03
WIC Slot 0:
FT1 PMC4351
PCB Serial Number : FOC07291NCW
Part Number : 73-8346-03
Board Revision : A0
RMA History : 00
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-01
CLEI Code : IP4I380GAA
WIC Slot 1:
FT1 PMC4351
PCB Serial Number : FOC07291P0T
Board Revision : A0
RMA History : 00
WIC Slot 2:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC1120341S
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
AIM ATM: 0
ATM AIM
Top Assy. Part Number : 800-06558-06
Board Revision : B0
Fab Version : 07
PCB Serial Number : FOC11114VBE
RMA History : 00
Product (FRU) Number : AIM-ATM
CLEI Code : CNUIALRAAA
Can u help me how we identify that it has two built in csu and dsu?
Mahesh
Rick
Rick
Hi Rick,
Thanks for your Help.
cheers
Mahesh Parmar
Hi rick,
how r you?
you said check on CCO which website is this?
thanks
