Community Member
How configurate a AS5400XM for dial-in dial-out in interface serial PRI with E1 signaling R2?
Hi partners,
I have one problem, i need programing a AS5400XM with interfaces PRI and signaling R2, how i cant enable the interfaces for dial-in and dial-out in this equipment, please somebody cant helpme.
------------------ show version ------------------
IOS (tm) 5400 Software (C5400-IS-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 24-May-05 19:22 by ssearch
Image text-base: 0x60008AFC, data-base: 0x61700000
ROM: System Bootstrap, Version 12.2(2r)XB, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 5400 Software (C5400-BOOT-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Router uptime is 18 minutes
System image file is "flash:c5400-is-mz.123-15.bin"
cisco AS5400HPX (R7K) processor (revision T) with 262144K/65536K bytes of memory.
Processor board ID JAE0617007K
R7000 CPU at 390MHz, Implementation 39, Rev 3.3, 256KB L2, 8192KB L3 Cache
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x31,
Board Hardware Version 16.6, Item Number 800-16091-01,
Board Revision B0, Serial Number JAE0617007K,
PLD/ISP Version 2.2,  Manufacture Date 23-Apr-2002.
Processor 0x14, MAC Address 0x0943450C4
Backplane HW Revision 1.0, Flash Type 3.3V
2 FastEthernet/IEEE 802.3 interface(s)
10 Serial network interface(s)
492 terminal line(s)
16 Channelized E1/PRI port(s)
512K bytes of non-volatile configuration memory.
65536K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
best regards.....
192
