08-03-2010 07:16 AM - edited 03-06-2019 12:17 PM
08-03-2010 08:03 AM
The configuration documents for the specific switch will show you how to do this. What is the switch model you are using ?
Jon
08-03-2010 08:25 AM
Hey,
first privat vlans are only possible in vtp mode transparent.
- create a primary vlan (vlan A; private-vlan primary)
- Optional you can create a isolated or community vlan and associate it with the primary (vlan B ;private-vlan isolated or private-vlan community;Enter primary vlan config mode and use private-vlan association [add | remove] secondary_vlan_list)
To verify use:
show vlan private-vlan [type]
or
show interfaces status
please look here to find the neccesarry commands in detail for 3750:
