Highlighted
Community Member
How do I download ASDM without a contract
My understanding is that ASDM is available free without a current contract but when I try to download the program I am advised I need a contract. Is there any way to get the current ASDM without a current license?
VIP Purple
Re: How do I download ASDM without a contract
when you go to your ASA admin page (https://ip-address-of-your-asa) there should be an option to download the files...
Community Member
All I get is a login screen and my admin username doesn't get me in - it looks like a VPN user access login page. At top left it says "CISCO SSL VPN Service"
VIP Purple
You need the IP address of the management interface.
Also, you need this configured (provided your managment IP address if in the 10.10.0/24 network):
http server enable 443
http 10.10.0.0 255.255.255.0 inside
Also, there should be a default version already on your disk0. Check the configuration for a line similar to the one below:
asdm image disk0:/asdm771.bin
Community Member
How do I ascertain the management IP if I don't know it?
VIP Purple
default IP address is I think 192.168.1.1.
Do you have access to the running configuration ? If so, can you post it ?
Community Member
I do, but I'm not comfortable posting it online given it's for the firewall. There is no asdm reference in the running-config though.
VIP Purple
See if you can work with this image...(rename it to .bin after downloading)...
Community Member
Okay, so I uploaded the .bin file to the firewall via tftp.
Do I have to restart the firewall for ASDM to load?
VIP Purple
sorry for the late response. I am in the Central European Time Zone...
Either way, copy the file you downloaded to disk0 with TFTP.
Once the file is on disk 0, add the command:
asdm image dosk0:/asdm782-151.bin
Make sure you have, as previously mentioned:
configured.
You should then be able to access ASDM by typing https://10.10.1.1
IP addressing is of course up to you, you might be using different addresses...
Community Member
Is disk0 the same as flash? I ran sho flash and this is what I've got (the results are the same if I run sho disk0):
105 14432256 Dec 31 2002 17:06:42 asa803-6-k8.bin
106 6851212 Jun 26 2008 07:50:44 asdm-603.bin
2 4096 Jul 14 2014 12:20:16 log
6 4096 Jul 14 2014 12:20:28 crypto_archive
107 24576 Dec 31 1979 17:00:00 FSCK0000.REC
108 6889764 May 29 2008 00:01:58 asdm-602.bin
110 4096 Dec 31 1979 17:00:00 FSCK0001.REC
111 26975568 May 18 2003 09:30:10 asdm.bin
112 13934592 Aug 13 2010 15:15:56 asa805-19-k8.bin
So it looks like asdm has been uploaded to this device before - I'm guessing I should use the asdm-603.bin file since it is newest?
VIP Purple
which firewall model do you have, and which version are you running ? The ASDM version I sent you is for 9.x, looking at the date on your files, my guess is you are running 8.x ? Can you check ?
Either way, you already have ASDM on your disk:
Add the below command to your configuration and try to access it again:
asdm image disk0:/asdm-603.bin
Community Member
It's an ASA 5520
Cisco Adaptive Security Appliance Software Version 8.0(3)6
Device Manager Version 7.8(2)151
Community Member
OKay, I did this, and this appears in my running-config:
no asdm history enable
But I still don't get anything when I go to https://10.10.1.1
VIP Purple
on which interface do you have 10.10.1.1 configured ?
Without seeing your running configuration it is just guesswork. Which ASA version are you running ? I'll try and find a sample configuration.
Post the output of 'show version'...
3330
