08-15-2007 09:46 AM - edited 03-05-2019 05:55 PM
How do I find the interface index on a 6509?
SNMP ineterafce monitoring is not working and they are asking me to verify the index. I know I have seen it before but I can't seem to find it again.
Dave
08-15-2007 10:29 AM
Hi Dave, I think this is what you are looking for.
08-15-2007 10:46 AM
It is exactly what I am looking for but, my IOS is only 12.1.
It is quite possible I saw it on another device with a higher IOS.
Is there another way to get it?
Thanks.
08-15-2007 11:49 AM
hi Dave, based on this doc this feature was intruduced in 12.2 and above, if you are in 12.1 this feature is not configured in the box you're trying to get this info.
Jorge
08-16-2007 06:00 AM
And there is not other way to get it right? :)
I am going to see if I can figure out how the indexing gets the values if it is simple I may be able to isolate it.
08-17-2007 11:11 AM
You should be able to snmpwalk it.
"snmpwalk
http://www.cisco.com/warp/public/477/SNMP/snmp_ifIndex40700.html
You can get snmpwalk from here:
http://net-snmp.sourceforge.net/download.html
The ifIndex OID and mib can be found here if you need it:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=true&objectInput=ifName
