12-05-2006 10:05 AM - edited 03-05-2019 01:11 PM
Hi There...There is a way to get the sh run on the 3550 to show the vlan 1,1002-1005 information using the sh run command and for the likes of me I can't remember what the command is. Does anyone know what it is?
12-05-2006 10:17 AM
show run displays the entire config. There is probably another command you are thinking of. Here's a couple:
show vlan
show interface status
show ip interface brief
12-06-2006 06:29 AM
I guess i didn't make my question very clear, there is some setting you can set on the 3550-12 and on the 4948 so that when someone does a sh run they get more information without resorting to other commands, this is good for copy and paste configs. The sh run normally doesn't show how VLAN1 and other VLAns are setup but there is a way to get them to show this along with the normal sh run stuff...
vlan 1
tb-vlan1 1002
tb-vlan2 1003
vlan 1002
tb-vlan1 1
tb-vlan2 1003
and so on, this is useful if you want to save the configs for future reference.
12-05-2006 10:23 AM
What exactly you are looking for. What kind of vlan information in show run.
You can use " Show vlan " command to check the vlan information and respective port in that vlan.
You cannot have vlan 1002-1005 vlans dispalyed in show run. they are the default vlans and you can check only in " show vlan "
If you are looking for some vlan interface outputs. You can use " show interface vlan 1" command.
Please find the link below of 3550 command refrence and check for any particular command if you are looking for :
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/cr/index.htm
HTH, Please rate if it does.
-amit singh
12-06-2006 06:43 AM
Hi there..Sorry to disagree with you but yes you can have the vlans displayed, please see my reply above, we have our exisitng vlans showing up in the sh run command but there was some setting to do this and I can't remember it, its been a while since I set a 3550-12 up. Note only basic vlan info will be displayed...
12-06-2006 08:33 AM
Usually changing the VTP mode to "transparent" makes your vlans and vtp config visible in the running-config.
Hope it helps!
Ramin
12-06-2006 10:00 AM
Hi There...Bingo, changing the vtp mode to transparent did the trick, thank-you!!! Now I can see the vlan info. Much appreciated!
