10-24-2008 08:34 AM - edited 03-06-2019 02:08 AM
how do you know wich series uses fiber module that have lc or Sc connection. cause I was @ the site and we had some cable ends issue. one end Lc to SC and the other is SC to SC.. But how I will know what is the hardware required for the rtr/switch so I can order the correct modules and advise the vendor to make the right cable ..
Solved! Go to Solution.
10-24-2008 09:03 AM
You need to look at the data sheets for the switch model and these will tell you what type of fibre connectors are supported.
If you go under "Product & Services" from Cisco home page and then select "Switches" then the model you are interested you can then look at the data sheets.
Attached is a link to data sheet for 4948 switches. Have a look at Table 2 which shows what type of fibre connectors are available on each model.
Jon
10-24-2008 08:40 AM
Hello Ocporbust,
LC ------ > SFP small format
SC ------ > GBIC classic GBIC
then also the type of fiber counts
Hope to help
Giuseppe
10-24-2008 08:45 AM
Giuseppe how r u Buddy!!!
I am still not clear about it , let say the inplementation requires fiber connections ,, and we have 4948 and 3550 ..now the 3550 takes sc to sc but the 4948 to 3550 one end is Lc and the other is SC .
10-24-2008 08:48 AM
That's fine. So to connect the 2 together the actual fibre cable you purchase must be SC-LC ie. one end will have a connector for an SC and the other end will have a connector for an LC.
Most cable manufactures will be able to supply these type of cables.
Jon
10-24-2008 08:55 AM
Thanks Jon
how I would now that 4948 only takes LC why not sc to sc as 3550 does,
10-24-2008 09:03 AM
Jon
10-24-2008 10:04 AM
Thank you all , will come back w/ more.. :-)
