How does a 2821 compare to a 3640 router?
We have a 3640 router with 64MB ram and only two 100MB interfaces. This router is averaging 75-85% with some 100% CPU during the day.
We'd like to upgrade this router to something that will handle 2-GB interfaces without having to move to the 7200 series.
Will the 2821 router with 256MB ram and two Gig interfaces work for us? Can it handle wire speed throughput? If not what is it's maximum throughput?
Thanks.
Re: How does a 2821 compare to a 3640 router?
The 2821 is positioned as a WAN edge router capable of handling about 4 T1 worth of sustained throughput with services such as stateful inspection and IDS turned on. It is hard to find performance numbers without services, and the number will kind of be an it depends, average packet size, type of traffic and other variables will come into play, but it definately is not wire speed with it's gig interfaces
Gold
Having some trouble posting a file that I got off these forums with that information.
These numbers assume 64byte packets.
The 3640 is between 25.6-36 mbps the 2821 is 87.04
This assume just simple port to port file transfer no extra feature. I would not take these numbers to mean anything about true rates but they do to a point let you compare routers.
You really shouldn't be using a router for ethernet to ethernet traffic. Almost all layer 3 switches are wire speed for almost all functions. The only time I would use a router is if I needed feature like NAT that are not supported on a switch. The main reason to use a router is when you need to hook up some form of circuit.
A layer3 switch (3560 or 3550) tends to be cheaper than a router also.
Purple
I would investigate what traffic is hitting this thing , that seems high for only 2 interfaces . What is the process driving the cpu ? Do a show proc cpu sort and post here maybe we can get a better idea . Must be a lot of traffic is not being fast or cef switched . Here is a good page to troubleshoot high cpu . Also look for any code bugs in the version you are running .Also check to make sure fast or cef switching is turned on , by doing a show ip interface command. It could be something someone with a virus or something like that in which case you might use netflow to trace it down.
http://www.cisco.com/en/US/products/hw/routers/ps147/prod_tech_notes_list.html
This router is the last hop before our internet layer with holds out firewalls and VPN concentrators - it is our gateway of last resort. Once traffic gets to this router we use static routes to direct VPN traffic to the concentrator and the rest of the traffic default routes to the firewall. The IOS version is 12.2(26) c3640-ik9s-mz.122-26.bin
I've attached a text file that shows the output of 'sh proc cpu sort'.
Here is the output of 'sh int stats':
ROC-INET-3640#sh int stats
FastEthernet0/0
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 74031 6698907 128932 10361991
Route cache 439693527 2800453100 367937696 1839498920
Total 439767558 2807152007 368066628 1849860911
FastEthernet0/1
Processor 327065 31655207 283649 27781160
Route cache 367202152 2526156708 439764160 3776128100
Total 367529217 2557811915 440047809 3803909260
ROC-INET-3640#
Is that the full output. I dont see anything worng with the CPU processes.It shows that router is not having any process which is behaving unusual.
If that is not the full output, Please try to paste it.
Check the output of the show interfaces and see if you see something unusual there, like a lots of broadcast. This is interesting. If I were you i would try to use a sniffer and sniff the router port connected to the network, just to see if it is processing some unknown virus or worms traffic. Enable " Ip accounting " on the interfaces and check if you some unusual traffic is being sent by some user.
HTH,
-amit singh
I opened up a TAC case and was told that we are pushing this router to its limits. They sent me a Router Performance sheet which rates the 3640, doing Fast/CEF switching, at 50 - 70,000 packets per second, or 25 - 36Mbps at 64byte size. And the throughput is less if ACLs, WCCP, QOS etc is applied which all three are in our case. We're trying to push much more than 36 Mbps throught the fastether interfaces and hence the CPU is being pegged.
So it is time to upgrade our router.
Bronze
I agree with the above post - try enabling IP Accounting and NBAR to make sure you don't have "junk" traffic consuming all your bandwidth, then worry about buying new hardware.
The PDF file you mention has been fairly accurate, among the devices I've actually tested. I know for encryption, the CPU load will increase but the 2800 maintains close to wire speeds, whereis the 3600 starts degrading throughput at an incredibly high rate.
I also agree a layer 3 switch would make more sense for Ethernet-Ethernet traffic.
With a layer 3 switch would I be able to do WCCP - without having to get into the 6500 switch models?
260
