How many 3650 can i connect together
Cisco Catalyst 3560 use SFP Interconnect Cable. How many switches do cisco recommend i can dasiy chain together?
Re: How many 3650 can i connect together
I believe the max is 9
There is a document on Cisco's website that suggests not having a network "diameter" of more than 7, or 7 switches diasy chained, because of Spanning-Tree. However, I am hard pressed to think why you would even want to do that.
If you want to cluster, you can have 16 switches... refer to the URL below
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00801347f8.shtml#import
If you want to do non-cluster with daisy chain, it is 9 switches.. refer to the URL below
http://www.cisco.com/en/US/partner/products/hw/modules/ps5455/prod_release_note09186a00800d9ca9.html#wp8535
Hope this helps.. let us know if you need anything else... rate replies if found useful..
Raj
Thanks for the information but the documents do not state any information about 3560. Can i dasiy chain 3 together
3 will be fine,in production ,people keeps the 7 limit due to STP.
278
