04-24-2008 12:45 AM - edited 03-05-2019 10:34 PM
Hi all, can switches/routers forward millions of pps without any issues ?
04-24-2008 01:11 AM
Hi Carl,
A switch or router can keep on forwarding the packets untill it experience some physical or logical problem. There is no limitation in terms of number of packets. These network devices are to be up all the times.
*Pls Rate if it Helps*
Rgs,
Jack
04-24-2008 04:45 AM
Hi Carl,
the data sheets will specify the forwarding rates for switches (in packets per second). Rates vary according to the switch models and supervisor cards used.
HTH,
Steve
04-24-2008 10:14 AM
Hi Carl,
You might find the following link useful that was posted before by someone else.
http://www.cisco.com/web/partners/tools/quickreference/index.html
Look under switch/router performance depending what you are looking for. The #'s are not exact because everyone's environment is different but it should give you a rough idea.
Tim
