03-04-2013 04:45 PM - edited 03-07-2019 12:03 PM
rsbd7k01-p-vdca(config)# monitor session 2
rsbd7k01-p-vdca(config-monitor)# source vlan ?
<1-3967>
rsbd7k01-p-vdca(config-monitor)# source vlan 1 - 3967
ERROR: vlan 33-3967: Number of source vlans exceeds maximum
Solved! Go to Solution.
03-04-2013 04:57 PM
The number of source vlan per SPAN session is 32.
Have a look at table-13 in this link
03-04-2013 04:57 PM
03-04-2013 05:34 PM
Thanks dude that was quick! You ROCK!!!
03-04-2013 05:47 PM
You are so lucky. I happened to have the Web page in front of me open and I was reading it today.
Thanks for the rating
12-02-2015 06:42 AM
Thank you Reza, it helped me a bunch. I was unable to find it using the regular means.
The link is still accurate but the table got shifted. The needed information is in Table 17:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/verified_scalability/b_Cisco_Nexus_7000_Series_NX-OS_Verified_Scalability_Guide.html#concept_2CDBB777A06146FA934560D7CDA37525
