11-21-2011 05:19 AM - edited 03-07-2019 03:30 AM
Good afternoon,
I am currently trying to figure out if it is possible if a router has 4 different networks to assign a different gateway of last resort other than
0.0.0.0 0.0.0.0 Dialer 0 for one network.
e.g. Network 172.16.16.0/24 is configured on the router, but all traffic traffic to internet from this network should not go over dialer 0 but over another
network the router knows, eg. a VPN connection.
is that possible and if, how?
I tried to have this arranged with access-lists, say first blocking all traffic for the particular network:
access-list 109 deny tcp 172.16.16.0 0.0.0.255 any
and then we allow it but only to a specific destination
access-list 109 permit tcp 172.16.16.0 0.0.0.255 host xxx.xxx.xxx.xxx <<< outbound Gateway for 172.16.16.0/24
I have the following questions:
Must both rules be in the same access-list?
How is standard access list 1 considered in this case, must i allow, deny or simply not naming the 172.16.16.0/24 network in access-list 1?
How to make use of the above sample access-list 109
Thank you and all the best!
David.
11-21-2011 05:50 AM
Hi David,
Yes this is very easy to accomplish using Policy Based Routing.
You must use a route-map to first match the traffic that you want to do something with, then set the next hop for that traffic.
ip access-list extended USE_OTHER_GATEWAY
deny ip 172.16.16.0 0.0.0.255 10.0.0.0 0.255.255.255
deny ip 172.16.16.0 0.0.0.255 192.168.0.0 0.0.255.255
deny ip 172.16.16.0 0.0.0.255 172.16.0.0 0.15.255.255
permit ip 172.16.16.0 0.0.0.255 any
route-map PBR_OTHER_GATWAY permit 10
match ip address USE_OTHER_GATEWAY
set ip next-hop 10.20.30.1
route-map PBR_OTHER_GATWAY permit 20
Interface Fa0/0
ip policy route-map PBR_OTHER_GATWAY
Hope That Helps!
Nick
11-21-2011 06:42 AM
Hi Nick,
in PBR ther's no need to configure a catch-all route-map statement because what is not matched will be routed via FIB/RIB and not PBR'd automatically. so the
route-map PBR_OTHER_GATWAY permit 20 statement is not mandatory.
Regards.
Alain
11-21-2011 06:44 AM
Hehe Righto - Force of habit using Route-maps with BGP ;-)
11-21-2011 06:52 AM
Hi Nick,
thanks for your reply.
For some reason the route-map is something I so far did not get running. Pls. see my previous quesion from another thread.
My problem is, that the traffic must go through a VPN tunnel which is fully functional already.
But I will give it one more try adapting your code.
Thanks & Regards,
David.
11-21-2011 07:58 AM
Hi David,
I've looked at your other thread regarding nest-hop recursive... I don't think we have a proper understanding of what you are trying to do.
Can you provide a simple network diagram? We might be able to advise better. Also, what device are you attempting this on?
Many Thanks,
Nick
11-21-2011 09:00 AM
Hi Nick,
What I try to do is quite easy. From a customers site where several public WIFI-Nets for the teenants are running, the www-traffi only must in order to comply with local law be routeted through a proxy to log it.
So I managed to configure a Cisco 3640 box which makes a DSL-PPPoE Internet-Con and as well a VPN Tunnel to our ISP PoP.
The www-concerned traffic goes through the VPN to us, we log it and that's it.
For some magic and thanks to your post I get now the www-traffic and all other if I wish through the tunnel to our site.
What was missing was an ip nat inside on our site on the tunnel interface.
I never knew that this is possible as the traffic at this point is still encrypted.
Anyway, I am unable to finalize the last step:
On our site I too stupid to manage, that the www traffic we receive on the tun 0 interface goes straight to the port 80 of the squid proxy what is directly connected.
instead doning so, our router shots the traffic directly over our backbone into the internet.
I would much appreciate it if you could help me with this fiinal step.
Thanks in avance and all the best.
David.
