02-17-2010 07:11 AM - edited 03-06-2019 09:44 AM
Dear friends,
How do i enable standby console on the 4500?
This is what i get when i try to access the standby console.
HH_GF_SW2-standby-console#sh ver
Standby console disabled.
Valid commands are: exit, logout
QHH_GF_SW2-standby-console#
I am not able to enter any show commands. Basically i want to know the DRAM on the standby supervisor?
I know that in 6500, you have the command standby console enable under main-cpu but i dont get this here.
QHH_GF_SW2(config)#redundancy
QHH_GF_SW2(config-red)#main
QHH_GF_SW2(config-red)#main-cpu
QHH_GF_SW2(config-r-mc)#st
QHH_GF_SW2(config-r-mc)#st?
% Unrecognized command
QHH_GF_SW2(config-r-mc)#?
Main CPU redundancy configuration commands:
auto-sync Sync elements
default Set a command to its defaults
exit Exit from main-cpu configuration mode
no Negate a command or set its defaults
QHH_GF_SW2(config-r-mc)#exit
QHH_GF_SW2(config-red)#exit
QHH_GF_SW2(config)#exit
I am using 4510-R-E with Sup 6-E and IOS version is 12.2(53)SG Enterprise services.
Thanks a lot
Gautam
02-17-2010 07:42 AM
Try using show bootvar / show redundancy command and check, else if you can afford a failover execute the command and check for the same.
regds
02-23-2010 10:39 AM
Dear Prem,
I am very sorry to get back late on this. I tried a switchover and i still get the same message.
Please find below the output of show bootvar / show redundancy:
HH_1F_SW1#show bootvar
BOOT variable = bootflash:/cat4500e-entservicesk9-mz.122-53.SG.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby BOOT variable = bootflash:/cat4500e-entservicesk9-mz.122-53.SG.bin,12;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
QHH_1F_SW1#show redundancy
Redundant System Information :
Available system uptime = 1 week, 1 day, 8 hours, 3 minutes
Switchovers system experienced = 1
Standby failures = 0
Last switchover reason = user forced
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 6
Current Software state = ACTIVE
Uptime in current state = 1 week, 1 day, 8 hours, 3 minutes
Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 12.2(53)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Jul-09 22:44 by prod_rel_team
BOOT = bootflash:/cat4500e-entservicesk9-mz.122-53.SG.bin,12;
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 5
Current Software state = STANDBY HOT
Uptime in current state = 0 minutes
