How to add IOS to a Catalyst 3500 switch with no files or IOS
I bought a switch off of ebay but the seller removed everything including the IOS image.  Does anyone know how to add an IOS image to the switch?  I do not know how to setup TFTP in order to load files in the current mode that the switch boots in.  Here is some output that may help you see my predicament more clearly.  I have switch images and other working routers and switches but
_________________________
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE
Compiled Mon 30-Apr-01 07:51 by devgoyal
starting...
Base ethernet MAC Address: 00:05:5e:aa:4d:80
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 3611648
flashfs[0]: flashfs fsck took 2 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
The system is unable to boot automatically because there
are no bootable files to boot.
switch:
switch: ?
           ? -- Present list of available commands
        boot -- Load and boot an executable image
         cat -- Concatenate (type) file(s)
        copy -- Copy a file
      delete -- Delete file(s)
         dir -- List files in directories
  flash_init -- Initialize flash filesystem(s)
      format -- Format a filesystem
        fsck -- Check filesystem consistency
        help -- Present list of available commands
load_helper -- Load and initialize a helper image
      memory -- Present memory heap utilization information
       mkdir -- Create dir(s)
        more -- Concatenate (display) file(s)
      rename -- Rename a file
       reset -- Reset the system
       rmdir -- Delete empty dir(s)
         set -- Set or display environment variables
   set_param -- Set system parameters in flash
       sleep -- Sleep a specified number of seconds
        trap -- Cause a software breakpoint to occur
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
switch: version
switch: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                  bs[3]: (read-only)
switch:
___________________________________
7 Replies 7
can you issue the following and post the output:
switch: flash_init
issue command:
switch: dir flash:
And post the output,
______________
switch:
switch: flash_init
...The flash is already initialized.
switch: dir flash:
Directory of flash:/
3611648 bytes available (1024 bytes used)
switch:
You just have to follow the procedure on the link above by leolaohoo.
You should be fine...
pjmonline
On new switches they come with a universal image and have licenses to unlock different feature set. Unless you have the need for ip services than you will most likely go with the standard image.
3500XL switches do not come with "universal" images.  It's purely a Layer 2, 2nd-generation of switches.
I would like to thank everyone for their help.  I finally got my switch running this morning.
