06-25-2008 06:02 AM - edited 03-05-2019 11:49 PM
Hi all. I've got a Cisco 877 to replace our old shoddy ADSL router.
I want to connect it to our internal network so the PC's and server can use it as the Internet gateway.
Now obviously i'll need to configure an IP address for them to look at, but when I try to conigure an IP address on E0, I get the 'go away, you can give a switchport and IP address fool' message...
I can rememeber something about needing to create a VLAN, give it an IP address and assign the switch port to that VLAN, but, alas, I cant remember how to do it.
Can someone help?
Thanks!!
Solved! Go to Solution.
06-25-2008 09:24 AM
If you use VLAN 1 as your interface VLAN, then you shouldn't have to do anything special to the access port. It should by default be a member of VLAN 1.
Make sure the port is a member of VLAN 1 by using 'switchport access vlan 1'
06-25-2008 06:05 AM
you'll need to issue the 'no switchport' command prior to attempting to put an IP address on that switchport.
06-25-2008 06:08 AM
Ah OK, they then become 'normal' interfaces then?
06-25-2008 06:09 AM
the 'no switchport' command makes the port a routed interface.
06-25-2008 06:13 AM
Ok, I get these choices, any reccomendations?
inetrtr(config-if)#no switchport ?
access Set access mode characteristics of the interface
mode Set trunking mode of the interface
priority Set 802.1p priorities
trunk Set trunking characteristics of the interface
voice Voice appliance attributes
06-25-2008 06:15 AM
Not on a 877 it doesn't.... The FastEthernet interfaces on the 877 are ONLY Layer-2 switchports - they can be trunks and Voice VLAN enabled access ports but they CAN'T be routed interfaces.
By default they are all assigned as access ports attached to VLAN 1 so you would need to create the VLAN SVI and assign an IP address to this:
interface VLAN 1
ip address 10.1.1.1 255.255.255.0
Andy
06-25-2008 06:19 AM
Right and then simply make the relevant port (E0) a member of VLAN 1
06-25-2008 09:24 AM
