11-12-2013 09:38 AM - edited 03-07-2019 04:34 PM
I'm trying to block netflix from our network using a catalyst 3550 switch, I can't just block www.netflix.com, but want to block the word "netflix" as a whole that way i'm assured that i will block it for sure.
11-12-2013 09:58 AM
I don't this 3550 supports content based filtering but we should be able to filter using IP address.
Thanks & Regards,
Karthick Murugan
CCIE#39285
11-12-2013 10:09 AM
my 2cents.. blocking IP may not not work fully as IP can change. Unless you have proxy etc, you can add a DNS entry in your internal DNS server (if available) points null or if you got only handful of PCs, add an entry in the 'host' file and make sure that users cannot edit the the hosts file.
Thx
MS
