05-02-2008 08:20 AM - edited 03-05-2019 10:44 PM
How do I direct logging data from the 2821 router to be stored on a workstation? I have downloaded Kiwi Syslog Daemon on to the workstation, however, logging is not captured. The command for the syslog server was configured on the router. Thanks
Solved! Go to Solution.
05-02-2008 10:07 AM
Jon,
On the production router, provided the following commands. Still nothing displays on the syslog server.
logging host 192.168.1.180
logging trap 6
exit
copy run start
05-02-2008 01:03 PM
Do you have logging facility in the 2821?
05-02-2008 01:16 PM
I have included the folowing statements.
logging on
logging host 192.168.1.180 [workstation/syslog computer]
logging trap 6
exit
copy run start
05-02-2008 01:20 PM
I prefer to send the router's logs to a separate computer to accept and store the logs. So far, I have not been successful in configuring Kiwi Syslog Daemon to accept the messages from the router.
05-02-2008 01:59 PM
Basic question: Is there a firewall running on the syslog host?
-John
05-02-2008 02:15 PM
Yes, Windows firewall is running on the syslog host.
05-02-2008 02:26 PM
Ok, either turn it off for testing or set an exclusion for UDP/514.
05-02-2008 02:29 PM
UDP/514 was added to exceptions, still no messages. Are you familiar with setting Kiwi Syslog?
05-02-2008 02:30 PM
I can ping from the Syslog computer to the router.
05-11-2008 04:47 PM
Hi Jon,
I got Kiwi Syslog working. The following are from syslogs on ASA5510 firewall. Do the two mssgs look right to you?
07:40:25: %ASA-4-419002: Duplicate TCP SYN from Inside: 192.168.1.170/3229 to outside:82.42.69.140/4219 with different initial sequence number
(I can not find who has IP 192.168.1.170. Trend Micro shows no one on the LAN .170
ASA-4-313005 : No matching connection for ICMP error message: icmp src outside: 76.189.113.82 dst inside: 207.105.y.x (type 3, code 1) on outside interface: Original payload: udp src 207.105.y.x/3919 dst 192.168.1.100/49593
Thanks.
Said
