01-24-2014 06:57 AM - edited 03-07-2019 05:46 PM
All,
we have uesrs complaining slowness when accessing few urls on internet currently which are routed through mpls ,now we want to re-direct the traffic from that user subnet and only to certain destination url /ips which are critical to the users to a different internet link terminated on ASA ,can this be done?
Thank You,
Kalyan.
Solved! Go to Solution.
01-24-2014 07:08 AM
Kaylan
If the user vlan is routed on a L3 device before going to either the MPLS router or the firewall you could use PBR on the L3 device (if supported).
But as Reza says, we need more info on your network layout.
Jon
01-24-2014 07:01 AM
So you have separate Internet connection for one user and that terminates on an ASA? If yes, you can put the default gateway for that user on the ASA and have it go out that specific connection.
01-24-2014 07:18 AM
Thanks for replying but i am looking to achieve this in a different way as Jon suggested below.
01-24-2014 07:08 AM
Kaylan
Jon
01-24-2014 07:41 AM
Thanks Jon for replying.
