Webcast-Catalyst9k
How to conf Sticky in ACE
Hi All,
I have configured sticky in ACE but show status sticky but it is showing zero connection and show database sticky showing empty..
What is the ACE model, which you are using now and how did you configured sticky now on your device?
Example of IP Address Sticky Configuration
The following example illustrates a running configuration that defines IP address stickiness.The IP address stickiness configuration appears in bold in the example.
In this configuration, the ACE uses IP address stickiness to stick a client to the same server for multiple subsequent connections as needed to complete a transaction using the client source IP address, the destination IP address, or both.
access-list ACL1 line 10 extended permit ip any any
probe icmp ICMP
  interval 2
  faildetect 2
  passdetect interval 2
rserver host SERVER1
  ip address 192.168.252.240
  inservice
rserver host SERVER2
  ip address 192.168.252.241
  inservice
rserver host SERVER3
  ip address 192.168.252.242
  inservice
serverfarm host SFARM1
  probe ICMP
  rserver SERVER1
    inservice
  rserver SERVER2
    inservice
  rserver SERVER3
    inservice
sticky ip-netmask 255.255.255.255 address both SGROUP1
  timeout 20
  replicate sticky
  serverfarm SFARM1
class-map match-all L4STICKY-IP_115:ANY_CLASS
  2 match virtual-address 192.168.120.115 any
policy-map type loadbalance first-match L7PLBSF_STICKY-NETMASK_POLICY
  class class-default
    sticky-serverfarm SGROUP1
policy-map multi-match L4SH-Gold-VIPs_POLICY
  class L4STICKY-IP_115:ANY_CLASS
    loadbalance vip inservice
    loadbalance policy L7PLBSF_STICKY-NETMASK_POLICY
    loadbalance vip icmp-reply
    nat dynamic 1 VLAN 120
interface vlan 120
  description Upstream VLAN_120 - Clients and VIPs
  ip address 192.168.120.1 255.255.255.0
  fragment chain 20
  fragment min-mtu 68
  access-group input ACL1
  nat-pool 1 192.168.120.70 192.168.120.70 netmask 255.255.255.0 pat
  service-policy input L4SH-Gold-VIPs_POLICY
  no shutdown
ip route 10.1.0.0 255.255.255.0 192.168.120.2
It Depends on your scenario as well. But this type of sticky is the basic method get the sticky table created and worked out. you can restrict it only with source not with destination something like that you can do with this.
Karthik
PFA... Please check the
PFA... Please check the attached conf but it is not showing the sticky connection..kindly suggested me any changes required from side conf...
c4710
c4710
This conf is good .. my
This conf is good .. my sticky conf is working fine...thanks for your help...
34
