09-15-2013 03:06 AM - edited 03-07-2019 03:28 PM
I have one DHCP server connect to the cisco switch. Port # 47 connect to DHCP server. Port # 48 connect to Dsl modem, Port # 1 to Port # 46 this ports for employees
How to configuration the switch ?
find below photo
Solved! Go to Solution.
09-15-2013 08:03 AM
If all your PCs are in the same subnet as the DHCP server, you don't need a helper address. The DHCP should assign IPs to hosts (as long as you have the correct scope configured on the DHCP server).
09-15-2013 10:05 AM
Hi.
All pc should be also in the same VLAN of DHCP server.
Carlo
09-15-2013 08:03 AM
09-15-2013 10:05 AM
Hi.
Carlo
