11-03-2011 08:23 AM - edited 03-07-2019 03:12 AM
Hi Support
i have an issue to connect a trunk between cisco switch and extreme switch
i have many vlans that i want to cross via a link between cisco 3750 switch and a Extreme Alpine 3800 switch
can someone help on this?
Solved! Go to Solution.
11-03-2011 08:55 AM
When i connect the cable to cisco port 1 (trunk configured), from a pc connected to cisco switch, i cannot ping extrme switch and vis versa
What do you mean , you connect a PC on an access port on the Cisco switch and you can't access the management vlan from extreme switch and the other way around?
What is config of cisco switch port you are connecting to ? what is IP config of the PC ? what is the management VLAN of extreme?
Alain.
11-03-2011 08:27 AM
What is the issue?
Also, can you provide configs from both 3800 and 3750?
11-03-2011 08:50 AM
Hi Reza,
here is the cisco trunk port configuration (only vlan 128
interface GigabitEthernet0/1
switchport mode trunk
switchport trunk allowed vlan 128,129
Here, the configuration on Extreme switch with vlan 128 and 129, the is the port 1:32
LIBRSS01:23 # sh ports 1 : 32 vlan info
Port 1:32 (Billing-Core1)
Name VID Protocol Addr Flags Proto Ports
OSS_VLAN 129 ------------------ -------- ANY 3/5
Billing 128 ------------------ -------- ANY 2/5
LIBRSS01:24 #
the cable between switch is a cross-over
11-03-2011 08:55 AM
Alain.
11-03-2011 09:09 AM
Hi Alain
My pc is connected to a access port on vlan 128,
and from it, i cannot ping another pc connected on vlan 128 on extreme switch
the cable between swicth is cross-over
11-03-2011 08:59 AM
Ok, so you are using the extreme as your router. On the 3750, can you verify:
if interface gi0/1 is in up up mode? verify the interface your PC is connected to is in up and up mode
verify if vlan 128 is in up and up mode. for all you can use sh ip int bri gi0/1 etc...
On the extreme side can you provide "sh vlan 128 det?
11-03-2011 09:05 AM
here is the sh vlan 128 on extreme switch
LIBRSS01:24 # sh vlan Billing
VLAN Interface[20-213] with name "Billing" created by user
Tagging: 802.1Q Tag 128
Priority: 802.1P Priority 7
STPD: None
Ignore-stp: Disabled on this vlan
Ignore-bpdu: Disabled on this vlan
Protocol: Match all unfiltered protocols.
Loopback: Disable
RateShape: Disable
QosProfile:QP1
QosIngress:None
Ports: 5. (Number of active ports=2)
Flags: (*) Active, Disabled
(B) BcastDisabled, (R) RateLimited, (L) Loopback
(g) Load Share Group
Untag: *2:10(SWI_IN_port14) 8:28
LIBRSS01:25 #
when i connect the cable, the ports on cisco and extreme switch are UP and linking
my pc is in an access port to vlan 128
from my pc, i cannot ping another pc in vlan 128 on extreme switch
11-03-2011 09:14 AM
Is the issue resolved? I see you marked the treat as resolved.
If not where is the default gateway for the vlan 128?
If it is supposed to be on the extreme, did you turn on "ip forwarding" an the extreme box?
11-03-2011 09:19 AM
Hi Reza,
the issue is not solve yet
The default gateway for vlan 128 is a firewall connected on extreme on a port in vlan 128
there is no ip address on vlan in extreme switch, then ip forwarding is not enable.
there is no ip address on cisco switch.
11-03-2011 09:31 AM
Aha, now there is firewall too.
PC-------3750--------extreme------firewall
is that how you connect them together?
what is the ip address of the PC and what is its default gateway?
what is the status of vlan 128 and gi0/1
sh ip int bri vlan 128
sh ip int bri gi0/1
on the extreme port 1/32 is not active
is the extrem side also Gig?
11-03-2011 10:47 AM
the pc ip is 192.168.5.120/24
gateway is 192.168.166 (fw ip)
vlan 128 and Gi0/1 are up
in extreme, the port 1:32 is fast
11-03-2011 12:20 PM
Still not working,
may, i need to check the spanning tree
11-10-2011 05:59 AM
My problem was solve by enable Spanning-tree on the Extreme switches
Without the STP enable on Extreme switch, its cause a loop on the network.
Thanks to all
