How to configure load balancing in default routing?
How to configure load balancing in default routing? How it works?..
Re: How to configure load balancing in default routing?
just make two defualt route for two deffrent distination with the same metric
like
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 2.2.2.2
this work as per flow loadbalanceing which is the defual u may chnage it per packet loadbalanceing
if helpful Rate
How it is working.. I have given in my router
ip route 0.0.0.0 0.0.0.0 s0/0
ip route 0.0.0.0 0.0.0.0 s0/1
Based on what traffic is flowing through either s0/0 or s0/1.. how it works
per flow
mean per source distination
if u have host opned ftp connection through s0/0
then another host oppned any other connection should go thorugh s0/1
this is per flow
per packect mean
the same host send packects the packects will be loadbalanced like first packect through s0/0 second packet thorugh s0/1 and so on
hope this helpful
2083
