How to configure MAC with IP bindings in cisco 2960 switch
Dear,
I have a cisco 2960 switch (c2960-lanlitek9-mz.122-50.SE2.bin)
& want to configure mac security with IP address bindings. Is it possible, please help.
Thanks..
16 Replies 16
Leo Laohoo
You are looking at Sticky MAC.
Secure MAC Addresses
Thanks Leo Laohoo,
Port security with mac working fine but how to bind IP address with MAC.
Please help..
Is the switch doing the role of a DHCP server?
yes, the switch doing the role of a DHCP server.
Post the config and the output to the command "sh ip dhcp bind".
Pls find the below output,
Switch#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
172.29.10.55        0100.1125.12bb.6f       Sep 11 2013 11:24 AM    Automatic
hi,
you could use the mac-address-table static command:
mac-address-table static vlan interface
Ok, thanks for the output.  What about the rest?
What is your network going to be like?  What IP address have you excluded?  What's your DNS?
Hi Leo Laohoo,
Pls find the details,
Network 172.29.10.0 255.255.255.0
default-router 172.29.10.1
exclude address 172.29.10.1 -172.29.10.50
name-server 172.25.10.10 172.25.10.11
thanks in advance...
do clear ip dhcp bind *
ip dhcp exclude 172.19.10.1 172.19.10.50
ip dhcp pool BLAH
network 172.29.10.0/24
default 172.29.10.1
exit
ip dhcp pool BOOM
client  0100.1125.12bb.6f
network /24
default 172.29.10.1
Please don't forget to rate our useful posts.
Hi Leo Laohoo,
Thanks for your prompt reply. I have configured but if i change the ip address the communication is still ok. I want to configure static IP address in the client machine and my object is if client change the ip address of their PC, the communication will off. I want to configure one port with one IP will work. Please help..
Hi Leo Laohoo,
Waiting for your kind response...
What do you want exactly? You want to bind the DHCP leased address to the device(MAC address) and refrain the user from changing this IP statically? I so then use the host pool config proposed by Leo and implement DHCP snooping +IP Source guard on your switch to prevent the user from changing the IP.
Alain
Hi Leo Laohoo/Alain
I have configured the following and working fine..thanks for your cooperation..
ip dhcp snooping vlan 100
ip dhcp snooping
interface FastEthernet0/47
switchport access vlan 100
switchport mode access
spanning-tree portfast
ip verify source
interface FastEthernet0/48
ip verify source
ip source binding 0011.2512.BB6F vlan 100 172.29.10.55 interface Fa0/47
ip source binding 1803.7345.982F vlan 100 172.29.10.61 interface Fa0/48
