09-09-2013 09:40 PM - edited 03-07-2019 03:22 PM
Dear,
I have a cisco 2960 switch (c2960-lanlitek9-mz.122-50.SE2.bin)
& want to configure mac security with IP address bindings. Is it possible, please help.
Thanks..
09-09-2013 09:47 PM
You are looking at Sticky MAC.
09-09-2013 09:56 PM
Thanks Leo Laohoo,
Port security with mac working fine but how to bind IP address with MAC.
Please help..
09-09-2013 10:03 PM
Is the switch doing the role of a DHCP server?
09-09-2013 10:10 PM
yes, the switch doing the role of a DHCP server.
09-09-2013 10:19 PM
Post the config and the output to the command "sh ip dhcp bind".
09-09-2013 10:25 PM
Pls find the below output,
Switch#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
172.29.10.55 0100.1125.12bb.6f Sep 11 2013 11:24 AM Automatic
09-09-2013 10:33 PM
hi,
you could use the mac-address-table static command:
09-09-2013 10:34 PM
Ok, thanks for the output. What about the rest?
What is your network going to be like? What IP address have you excluded? What's your DNS?
09-09-2013 10:40 PM
Hi Leo Laohoo,
Pls find the details,
Network 172.29.10.0 255.255.255.0
default-router 172.29.10.1
exclude address 172.29.10.1 -172.29.10.50
name-server 172.25.10.10 172.25.10.11
thanks in advance...
09-09-2013 10:48 PM
do clear ip dhcp bind *
ip dhcp exclude 172.19.10.1 172.19.10.50
ip dhcp pool BLAH
network 172.29.10.0/24
default 172.29.10.1
exit
ip dhcp pool BOOM
client 0100.1125.12bb.6f
network
default 172.29.10.1
Please don't forget to rate our useful posts.
09-09-2013 11:13 PM
Hi Leo Laohoo,
Thanks for your prompt reply. I have configured but if i change the ip address the communication is still ok. I want to configure static IP address in the client machine and my object is if client change the ip address of their PC, the communication will off. I want to configure one port with one IP will work. Please help..
09-10-2013 12:25 AM
Hi Leo Laohoo,
Waiting for your kind response...
09-10-2013 01:19 AM
What do you want exactly? You want to bind the DHCP leased address to the device(MAC address) and refrain the user from changing this IP statically? I so then use the host pool config proposed by Leo and implement DHCP snooping +IP Source guard on your switch to prevent the user from changing the IP.
Alain
09-10-2013 02:08 AM
Hi Leo Laohoo/Alain
I have configured the following and working fine..thanks for your cooperation..
ip dhcp snooping vlan 100
ip dhcp snooping
interface FastEthernet0/47
switchport access vlan 100
switchport mode access
spanning-tree portfast
ip verify source
interface FastEthernet0/48
ip verify source
ip source binding 0011.2512.BB6F vlan 100 172.29.10.55 interface Fa0/47
ip source binding 1803.7345.982F vlan 100 172.29.10.61 interface Fa0/48
