How to configure NAT with VLAN
davidmejia
My question is How can I configure NAT with Router Cisco 7200 using virtual interfaces VLAN or Loopback?
I have to configure One vlan with Private IPs and the other with public IPs
I tried with this configuration but it doesn't work. Any suggestions?
Thanks in advance
interface Loopback50
ip address 200.105.127.190 255.255.255.252
ip nat outside
ip virtual-reassembly
interface FastEthernet2/0.50
description IP Private
encapsulation dot1Q 50
ip nat inside
ip route 200.105.127.188 255.255.255.252 Loopback50
ip nat inside source list 50 interface Loopback50 overload
access-list 50 permit 192.168.1.0 0.0.0.255
9 Replies 9
t814687
You can not do NAT on a loopback interface. You will have to use subinterfaces or physical interfaces on the router.
serg
I have to configure the Router with VLANs and I tried with subinterfaces, but it doesn`t work
Any Suggestion?
interface FastEthernet2/0.51
encapsulation dot1Q 51
ip nat outside
ip nat inside
ip route 200.105.127.188 255.255.255.252 FastEthernet2/0.51
ip nat inside source list 50 interface FastEthernet2/0.51 overload
David,
That should work...can you post debug ip nat ?
another thing to try is this:
ip nat pool ovrld 200.105.127.190 200.105.127.190 prefix 30
ip nat inside source list 50 pool ovrld overload
This will PAT all the outgoing traffic to your outside interface. Try and let me know.
serg
Also I assume you have your default route to the internet upstream neighbur on the router, right?
and I do not see you need that static route to FastEthernet2/0.51 .
serg
Hi, serg
Well, This is the configuration of my router Cisco 7200 and the IOS is
Cisco IOS Software, c7200-js-mz.124-12c.bin
no ip address
duplex auto
speed auto
ip nat outside
ip nat inside
ip route 0.0.0.0 0.0.0.0 serial0/0
I turned on the debug ip nat.
Router#debug ip nat
IP NAT debugging is on
Router#
Router#sh ip nat translations
Router#
I tried with the other configuration that you gave me, but it still isn`t working.
Router#
And This is the log on the Router
*Apr 25 17:11:56.454: NAT: reaping portlist proto 6 globaladdr 200.105.135.190
*Apr 25 17:12:12.246: NAT: Reserved 200.105.135.190 for PAT
*Apr 25 17:12:12.246: ipnat_add_dynamic_cfg_common: id 6, flag 5, range 1
*Apr 25 17:12:12.246: id 6, flags 0, domain 0, lookup 0, aclnum 32, aclname 50, mapname idb 0x00000000
*Apr 25 17:12:12.250: poolstart 200.105.135.190 poolend 200.105.135.190
when you turn debugging on can you generate some traffic to the outside and see if you getting anything on the console/terminal session?
Are you telnetting to the router, if yes you need "term mon" command to see the live output
default gateway does not seem right to me if you are using subniterface. What is this ip 200.105.127.188 ? your router should point to your next hop upstream router IP to get to the internet , not to this serial0/0 if I understand this correctly.
Pravin Phadte
Level 5
Level 5
Can you try by adding a route statement.
Ip route 192.168.1.0 255.255.255.0 fastethernet2/0.50
I added this route but it still isn`t working
Do you have any other suggestion or configuration?
ip route 192.168.1.0 255.255.255.0 FastEthernet2/0.50
ip nat pool natpool 200.105.127.190 200.105.127.190 netmask 255.255.255.252
ip nat inside source list 107 pool natpool overload
access-list 107 permit ip 192.168.1.0 0.0.0.255 any
also try if the above config does not work with this route.
ip route 200.105.127.190 255.255.255.252 FastEthernet2/0.50
Also let me know if u have any default route
