How to configure port for Hypervisor
Hi Guys,
Our system Administration team create 1 hypervisor VMware server. Now they want to create more VMs on same machine but in different VLANs.
What configuration required to do on my 6506-E Core Switch.
Here is what I did which didn't work. If I do switchport mode access, hypervisor server becomes accessible but I do it in trunk mode I can't ping hypervior server. Please help.
interface GigabitEthernet3/29
switchport
switchport access vlan 33
switchport trunk allowed vlan 20,33,222
switchport mode trunk
load-interval 30
speed 1000
duplex full
no snmp trap link-status
Hypervisor Server IP : 10.1.33.21
Everyone's tags (7)
1 ACCEPTED SOLUTION
Re: How to configure port for Hypervisor
I seem to remember something about VMware not supporting the dot1q trunk and wanted the port to be configured using "mode on".
The physical NIC in the hyper visor needs to be carved out and all VLANs besides the native need to be tagged.
VIP Super Bronze
Are these vlans created on the VM.  If yes, the ESX needs to be configured as trunk with dot1q also.
http://kb.vmware.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&docTypeID=DT_KB_1_1&externalId=1003825
Also,
Since the port is a trunk port, you don't this command anymore
Hi Reza,
VLANs are created on Cisco Switch. but yes on ESX Server there are VMs created in different VLANs
Problem solved.
Issue was native vlan was also in same group.
So this helped: ->
Thanks a lot
735
