11-21-2008 12:54 AM - edited 03-06-2019 02:36 AM
i bought a cisco 871 router i had my vlan connected to wan but i lost connection with a certain nat command
i cant reestablish the routing
cisco 871
vlan router ip 10.10.10.1 no dhcp computer 10.10.10.2 with
dns servers from the internet provider gateway 10.0.0.138 adsl modem
router ip on wan is 10.0.0.10
i just want to interet for a start
i route fastethernet4 (wanport) to 0.0.0.0 submask 0.0.0.0 but nothing happens
jil
12-12-2008 01:37 PM
You should be hitting the Cisco router w/ SDM by using its internal IP (LAN IP).
__
Edison.
12-12-2008 02:10 PM
but i make connection via the wan
12-12-2008 02:14 PM
Ah, you are managing the router via remote, got you.
You can change the http port from 80 to another number and manage SDM from this new port number.
The command is ip http port [value]
HTH,
__
Edison.
12-12-2008 02:11 PM
/w ?
12-14-2008 07:33 AM
understand the command is to log in from wan
to host cccc with port bbbb
ip nat inside source static tcp cccc bbbb interface FastEthernet4 bbbb
but the logic of cisco fails me.
in sdm i have to fill in translating from adres the host on the inside , but i make the call from outside wan.
the command sentence also speaks of source adres but my logic says the source adres is that of the host that trys to make connection with the inside adres.
what do i miss ?
12-14-2008 08:15 AM
I'm sorry, can you explain your confusion one more time? I didn't understand the message.
__
Edison.
12-14-2008 09:09 AM
this is the command which works to let an host from wan(=outside) = fastethernet4 to remote desktop on port bbbb on a hostserver cccc on the vlan(=inside).
but the command names the inside adres as source(=originating) but it is a host on the wan which want to connect to the inside host
in the sdm screen the original adres is cccc, the thranslated adres the ipadres of the cisco router on the ethernet4 interface.
so in my logic the source adres or originating adres is the ip adres of the wan host because he wants to communicate with the server.
so ehy is the original inside adres the source adres.
12-14-2008 12:05 PM
next problem
i have an public ip adres aaaa , then an adslmodem with inside adres ccc138 the fa4 of the cisco is connected to it with ip cccc01.
can i make acces rules with public ip adresses on the outside lan ccc0 of my cisco router because he sees only the gateway ccc138.
should i pass the public ip adres to my cisco router through the adslmodem to make acces lists on basis of public ip adresses of hosts i want to allow ?
