how to copy the bootldr image from SP slot0 (pc card) to RP bootflash:
Dear ,
Please explain me the conversation title.
swamy
Re: how to copy the bootldr image from SP slot0 (pc card) to RP
Hi Swamy,
Go to the console prompt of RP Rommon and from ther issue a command
copy sup-slot0: bootflash:
Remember you will not be able to issue dir slot0: from RP rommon prompt.So copy the image name from SP prompt.
Update if it worked.
Ankur
Ankur,
Thanks fr your prompt reply.
I tried the command.The copy command is not acceptrd.
I believe that we have to xmodem the bootloader to the RP DRAM as u suggested then boot to the RP then tftp to the RP bootflash
Last time i asked the foolish question.
I understand the concept and corrected.
When I download the image to the local drive to xmodem then That image is in the local drive to tftp to the RP bootflash
222
