03-31-2014 11:00 AM - edited 03-07-2019 06:56 PM
On Catalyst3750 with default SDM template, cisco says up to 2K unicast/indirect routes will be stored in TCAM and will be fast switched.
I have 2 questions aboud this.
If one destination has 4 next-hops, should I count this as 4 route?
For static route with interface option, is this direct route or indirect route?
03-31-2014 11:39 AM
If one destination has 4 next-hops, should I count this as 4 route? one route
For static route with interface option, is this direct route or indirect route? Based on the fact that the router consideres the destination is directly connected I would say direct.
Jcarvaja
04-01-2014 05:24 AM
Thank you for the response.
Do you have any document explained that single destination with multiple next-hops uses only one route in TCAM memory?
I think it's natural that number of next-hops has some impact to TCAM utilization.
