06-25-2012 09:19 AM - edited 03-07-2019 07:26 AM
hi ,
i have the sumbet x.x.x.x/27 ,
i have a router that connect with interent , and want to give a group of ips a specific cir , and this cir be shared betweeen these ips ,
how to use policy map , and how to apply it ??
regards
Solved! Go to Solution.
06-25-2012 09:31 AM
first you have to select your subnets with an access-list:
access-list 20 permit [subnet / wildcard]
then you have to map the access-list to a class:
class-map CIR
match access-group 20
now create the policy-map:
policy-map RATE_LIMIT
class CIR
bandwidth [rate]
police [the rate limit] exceed-action [drop]
and then bind to the output of the interface towards internet:
int f0/0
service-policy out RATE_LIMIT
Hope it Helps and plz Rate helpful posts.
Soroush.
06-25-2012 11:27 AM
using an extended access-list with that description, is similar to one i wrote for you, it is fine. but, you have to use that ACL in the service policy, just like what i did. i didnt exactly understand what u meant by applying it, just to let you know, in this application acl is to define traffic to be used in the service policy only.
i dont think you need them in that service policy, bandwidth and police commands with correct setting would do just fine.
Hope it Helps,
Soroush.
06-25-2012 09:31 AM
class-map CIR
class CIR
bandwidth [rate]
int f0/0
Soroush.
06-25-2012 09:33 AM
another question ,
how to make priority for this subnet to be always have the abndwidth 20 mega?
i mean that my internet bw = 40 mega ,
and i have more subnets that the above subnet ,
but i want to reserve the bw to this subnet to be dedicated whatever there were congestion or not ??
with my best regards
06-25-2012 09:38 AM
I just editted my original post, added a BANDWIDTH command under service-policy. you dont use Priority command for this application, you use bandwidth to guarantee a minimum bw.
Soroush.
06-25-2012 09:54 AM
hi , im really thankful for u, but another question ,
in the access list i did an extended acl and matched the my subnet as source and the destination i put it any ,
now the interface i applied it out , .
is that ok ??
another question , i want to ask about those two command:
1-Average Rate Traffic Shaping
2- cir 2000000 (bps)
do i need them to achive my goal ??
06-25-2012 11:27 AM
Hope it Helps,
Soroush.
06-25-2012 11:30 AM
u r right ,
i do it
thanks for ur help ad really apppreciating ur precious reply .
regards
