How to create stack with two 3750G switches
darrenriley5
I need to create a switch stack with two 3750G switches. What's the best way to do this?
kumarkrishnar
The stacking configuration done automatically when you are connect the stack cable back side of the switch
the connection will be like this
switch 1  stack port 1  need to connnect switch 2 stack port 2
the same vise versa switch 1 stack port 2  need connect switch 2 stack port 1
If you want one switch always act as a master you can set the priority to the switch
conf t
switch 1  priority  5 ( you can set any number  should be highest number in the stacked switches )
regards
krishna kumar
Reza Sharifi
Hello Darren,
After stacking them, decide witch switch you want to be the master and give that one a higher priority.  The priority is from 1 to 15 with 15 being the highest.
Also make sure you run the same exact IOS on both switches.
Please refer to this document for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swstack.html
Reza
