How to determine which interface is used for site to site connection
site A (CATALYST4006)and Site B(CISCO3750) are connected via 100Megs Lan EXTENSION.How do we determine which interfaces/ports on these switches are actually used for this site to site connection?I did "sh cdp neigh'did not help and I do not have physical access to switches.
  • LAN Switching and Routing
Hall of Fame Super Silver
Re: How to determine which interface is used for site to site co
look for the MAC address associated in the ARP table with the ip address of an host in site B from a site A host/gateway and then look for that MAC address in the site A switch cam table with
sh mac-address-table address
the outgoing interface that appears in the rightmost column is the interface from site A to site B
Hope to help
Giuseppe
Silver
Another idea in case the ARP entry for the other switch is not present is checking the system's MAC of the switch. Look in the show spanning-tree
Core3560#sh spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32768
Address 000e.8389.8d00
Cost 19
Port 12 (FastEthernet0/10)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
>>>>>>>> Address 0014.f246.e080
Aging Time 300
Check the Bridge ID MAC address of Switch A and then look in the MAC table of Switch B for this MAC and you will find the port used to connect between each other
105
