How to disable keepalive on Catalyst 3560
John Kellen
I need to disable the keepalive on two gigabit uplink ports.
Can anyone tell me what commands i need to use exactly to disable keepalive on  GigabitEthernet0/1 and  GigabitEthernet0/2
VMINFswitch>enable
VMINFswitch#configure terminal
VMINFswitch# . . . ?
Thanks a lot..
John
Hi John,
go under the interfaces in questions
interface range gig0/1 - 2
no keepalive
That should do the trick
Cheers,
Conor
Hi John,
no keepalive
Cheers,
Conor
Thank you Conor
