10-17-2013 05:33 AM - edited 03-07-2019 04:05 PM
i have cisco cli router. I can access it through using its internet gateway address (http) from any location out of my office.i need to disable its http remote management access for all outer world except me.
how can i do it, please tell me specific commands to put in the CLI for this purpose.thx
10-17-2013 05:46 AM
Try these commands:
config t
no ip http server
no ip http secure-server
10-17-2013 05:54 AM
thanks reza.,
10-17-2013 05:49 AM
use " no ip http server" in global configuration mode, if it is being accessed throgh http or use "no ip https server "
in global configuration mode,if it is being accessed through https
10-17-2013 11:53 AM
If you want to maintain your ability to access the switch remotely through HTTP then you can't just use "no ip http server", that will prevent all http access. Instead, you would have to know what remote IP you DO want to allow and use an access-class to allow that address and disallow all others
access-list 1 permit host
ip http access-class 1
