how to do etherchannel
hi
currently my cat6500 (vss) two 10 gig ports link to another cat6500 ( no vss). I want to make etherchannel to bind them and make a 20g link.
if I configure as below, will it has any problem? I guess I will put VSS as channel active mode, and another cat6500 which link to internet will set channel mode passive, is it correct?
interface Portchannel1
switchport
swithport trunk encapsulation dot1q
swithport mode trunk
switchport nonegotiate
udld port
mls qos trust dhcp
spanning-tree link-type point-to-point
interface TenGigabitEthernet1/13/1
  switchport
  swithc mode trunk
  udld port
  mls qos trust dscp
  channel-protocol lacp
  channel-group 1 mode active
any comments will  be apprecaited
thanks in advance
julxu
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: how to do etherchannel
Hi julxu,
If I understand you question correctly, you have an access layer 6500 switch that needs to connect to a pair of VSS switches.  If that is the case, Cisco's recommendation is to use PAGP, so the Etherchannel can be used for Dual-active detection mechanism.  For Dual-active detection LACP is not supported.
Reza
VIP Super Bronze
not sure if I understand what you mean by virtual domain.  If you are planning to create a VSS pair, they both will be in the same domain.  If you have multiple VSS pairs then each pair need to be in a separate domain
VIP Super Bronze
Hi julxu,
Reza
so, do I need create virtual domain?
VIP Super Bronze
556
