01-12-2012 05:01 PM - edited 03-07-2019 04:19 AM
hi everyone,
can you help me regarding on my problem in our router, im new user of cisco router i can access the hardware and login in the account but the problem is if i use the command "enable" asking for a password, old I.T. personnel who setup this router already resign.
what is the posible solution to edit tha config please help me.
thanks
lei
Solved! Go to Solution.
01-12-2012 05:33 PM
Password Recovery Procedure for the Cisco 1700 and 1800 Series Routers
If your client cannot do a "Ctrl+Break", then eject the CF and reboot the router. Without the CF, the router will immediately go into ROMmon. Once here, re-insert the CF.
Please don't forget to rate our useful posts. Thanks.
01-12-2012 05:33 PM
01-12-2012 06:44 PM
Thank you for the rating. I hope the recommendation helps.
