08-13-2007 11:23 PM - edited 03-05-2019 05:52 PM
IOS 12.2(25)SEE2
Command in configuration mode does't exist
IP MULTICAST-ROUTING DISTRIBUTED
08-13-2007 11:54 PM
what kind of IOS is it? IP base? I think for enabling routing on the 3560 you need at least the advanced ip services but i am not sure.
Yves
08-14-2007 12:34 AM
My IOS is IPBASE but standard IP routing is implemented in this image. I have configured my network with VLANs, This switch routing comunication between this VLANs.
08-14-2007 01:01 AM
As Yves has said IP Base does not support multicast routing. IP Base does support basic inter-vlan routing + RIP but if you want more advanced routing protocol support + multicast then you need the IP Services image.
Jon
08-14-2007 02:55 AM
Oou :) Thank you
