Community Member
How to enable WS-C4507R-E web management
Hi all,
Does anyone know how to enable WS-C4507R-E web management?
Usually I will download .Tar image which has html file on it and I will configure the ip http path to point to it. I will also configure ip http server, authentication local....etc and Thats it!
But as for C4507R-E, I can;t find .tar image file.
So how can I enable web management on a C4506???
Thanks in advance
Ryan
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: How to enable WS-C4507R-E web management
Ryan
As far as i know the 4500 like the 6500 doesn't support the same setup as the 3560/3750 switches ie. you don't get a .tar file which expands into a directory for the 4500/6500.
You can use Cisco Network Assistant to configure the 4500. You will need to download the software for this separately as it doesn't come bundled with the IOS. Attached is a link to configuring CNA for the 4500 -
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst4500/12.2/25ewa/configuration/guide/netasist.html
You can download Network Assistant, which is free, from this link (note this link is also at the start of the doc above)  -
CNA
Jon
Highlighted
Community Member
Hi All,
Anyone has any idea on how to enable and access C4507 web console??
Ryan
Ryan
CNA
Jon
Community Member
Hi Jon,
You are absoutely correct!!! Thanks alot!! I just tried CNA yesterday... it worked fine.
Thanks very much!!!
Ryan Ho
1129
