08-31-2013 06:25 PM - edited 03-07-2019 03:14 PM
Hi All,
need help I am able to get in to r1 device, but when I tried
the exit "CTRL+SHIFT+6" plus "x"doesn't work - I am using Windows 7/64 and PuTTY
Any Suggestions? / Thank you
Here is what I got
Current configuration:
version 11.1
service udp-small-servers
service tcp-small-servers
hostname IMAACCESSSERVER
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip host r1 2001 10.10.10.10
ip host r2 2002 10.10.10.10
ip host r3 2003 10.10.10.10
no ip classless
logging buffered
line con 0
line 1 16
no exec
exec-timeout 0 0
transport input telnet
line aux 0
line vty 0 4
login
end
Solved! Go to Solution.
09-01-2013 10:23 AM
Hi Antonio,
I'm running windows 7/64 and putty, with no problem, just a thought, the key sequence is CTRL+Shift+6, release these three then press x. Other than that, I can't see any reason why it's not working.
Cheers
Mark
09-01-2013 10:24 AM
Ok, you can put command "transport input telnet" back to your line.
Are you doing CTRL+SHIFT+6 than release then x and NOT CTRL+SHIFT+6 x at the same time.
You have to release the keys after you do CTRL+SHIFT+6 and than press x.
08-31-2013 09:18 PM
Have a look at this link for config example:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Under line 1 16
Try removing this command and test again.
09-01-2013 04:33 AM
change with Secure CRT
and i totally agree with reze
rete it use full post
09-01-2013 09:45 AM
Thank you for your input on this issue
I tried the following
When I removed the
I got the following when I tried to connect to unit R1
IMAACCESSSERVER#r1
Trying r1 (10.10.10.10, 2001)...
% Connection refused by remote host
Also I change from PuTTY to Secure CRT
but still have the same issue
my next try is to get a diferent laptop with XPPSP3.. and let see what happens!
09-01-2013 10:24 AM
09-01-2013 10:23 AM
Hi Antonio,
Cheers
Mark
09-01-2013 11:01 AM
GREAT.........
and
Working............Thank you for the Input... RELEASE the MAGIC word... Have a good day!!!
09-01-2013 01:40 PM
Glad to help Antonio.
Thanks for the rating!
Reza
