Community Member
How to find out where message is coming from and stop it
Hey folks, on my recently configured c2950-i6q4l2-mz.121-22.ea4a.bin I keep getting the message below. Is there any IOS command to let me pinpoint from which process and reason this message is coming from?
sw#
*Feb 28 16:35:12.031: %IP_SNMP-3-SOCKET: can't open UDP socket
*Feb 28 16:35:12: Unable to open socket on port 161
*Feb 28 16:36:12.031: %IP_SNMP-3-SOCKET: can't open UDP socket
*Feb 28 16:36:12: Unable to open socket on port 161
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: How to find out where message is coming from and stop it
Marlon
Can you type "no snmp-server" from global config.
Jon
Marlon
Check your SNMP config on the switch or alternatively post the config.
Jon
Hall of Fame Super Silver
Hello Marlon,
have you configured SNMP on this device ?
you can check with
sh snmp
sh run | inc snmp
UDP port 161 is SNMP, UDP port 162 is for SNMP traps
if SNMP is configured the message is telling that the switch is not able to allocate an UDP socket to answer to an SNMP get that comes from a network management system.
check free memory with
sh proc mem | inc Free
Hope to help
Giuseppe
Community Member
This is the strange part:
If i do 'sh run | inc snmp' the only command related to snmp is:
sw#show run | in snmp
snmp-server engineID local 900000070200001CC1C02C50
Then I do
config t 'no snmp-server engineID'
the 'cant open UDP socket' message persists.
Then I do again 'show run | in snmp' and such entry remains in the configuration.
Any ideas on how to get rid of this?
Marlon
Jon
Community Member
The 'no snmp-server' did it.
Well, I can't quite understand why by typing the entire string the command was not removed though.
Thank you very much folks.
No problem Marlon, glad to have helped.
Jon
610
