Community Member
How to Identify the range of only connected ports
Hi all,
How do I identify the range of all connected ports in 6509 IOS ver 12.1.
Show interface description provide list of all ports with their status, I am interested in identifying only the range of ports which are connected or in 'up up' status.
Ex:
3/10 up
3/11 up
3/12 up
3/13 down
3/14 up
3/15 down
3/16 up
.... there are bout 300 ports
Desired output is 3/10 - 12,3/14, 3/16 so that I can use range command to work on all the ports in up status. Any tool, tip is greately appreciated.
Re: How to Identify the range of only connected ports
Kindly use, "show ip interface brief | i up".
HTH,
Mohammed Mahmoud.
Bronze
I think better to use "show ip interface brief | exclude down "
This will show you interface with both interface and protocol UP status and will exclude all the "DOWN" status (with even protocol down)
rgds
This command will give the Interfaces which are up & the VLAN they are in & the Description
show interfaces status | include connected
HTH - Pls rate if useful
107
