In a 7206-VXR/NP-G1 with shaping on an interface, there is a 'Shaping Active' field that reads 'no' or 'yes' depending if shaping is occurring. When 'active' the packets delayed and bytes delayed counters work also.
example:
GigabitEthernet0/3.82
Service-policy output: WAN-100MB-speed_with_10MB_voice
Class-map: class-default (match-any)
914452179 packets, 197638327821 bytes
30 second offered rate 252000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
99920000/99920000 624500 2498000 2498000 25 312250
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 914452475 69931741 0 0 no
However, in a 7604 with a shaping policy applied to a 2xGE SPA gig interface, there is no 'active' shaping indicator.
example:
GigabitEthernet2/1/1.82
Counters last updated 00:00:10 ago
485362917 packets, 109753594669 bytes
30 second offered rate 3721000 bps, drop rate 0 bps
Match: any
Queueing
queue limit 24980 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 485355796/109751981653
shape (average) cir 99920000, bc 399680, be 399680
target shape rate 99920000
Service-policy : QOS_classes_6Video_110voice
queue stats for all priority classes:
Queueing
queue limit 2500 packets
(pkts output/bytes output) 470937881/101388419100
In the 7604 how does one tell if shaping is occurring an a particular moment like in the 7206?
