How to login in Cisco E 500 switch
how to login into cisco catalyst express 500 switch?
There is no dedicated console/ management port on the switch.
Kindly suggest the login procedure.
Regards.
1 REPLY
Re: How to login in Cisco E 500 switch
Hi moorthy1977,
[Pls rate if it works]
To login Cisco E500 do the following
1. Connect your PC/laptop NIC with a stright cable to the Port1 of Cisco ES500.
2. Open IE and type http://192.168.1.1 or
http://192.168.0.1 and for recovery 10.10.10.10
Note: To bring it factory default, pls press the reset button
Goutam
Pls rate if it works.
697
