Community Member
How to make 2 ways multicasting traffic?
Good day,
I have a network with multicast (pim sparse mode). My network topology is made up for stations transmitin multicast video towards the Data Centre. Actually the multicast goes just in one way, I mean, from the remote stations to the Data Centre. My problem is that I have one application in the Data Centre that needs to use multicast towards the stations, that means that my originally receiver becomes a new active multicast source, so I need to define the multicast in the routers upstream as well. How could I do this?
Thank you very much in advance,
Best regards,
Alberto
Everyone's tags (1)
Re: How to make 2 ways multicasting traffic?
Hi Alberto,
are remote stations > datacentre  layer 3 ?
you say you have pim sparse mode multicast network already , do you have static RP or Auto RP?
For starters you will need to put pim sparse mode on Data centre interface ,  so that the router knows that the multicat stream exists in mroute table
could you give us bit more details on your current multicast set up
Many thanks
Community Member
Solved...
Thank you
299
