Community Member
How to make a port on the router static
My current Cisco Router 1812 configs. are as:
1. My DSL connects to the FE0 port.
2. My ports FE2-FE9 are automatically assigned IP addresses via the DHCP server from VLAN 1.
What I want to do is stay on the same vlan but assign my printer which is hooked up to my FE2 port a static IP how do I go about doing this.
Re: How to make a port on the router static
Community Member
I dont know i set everything up via SDM so it was easy to configure.
Under SDM -> DHCP, you should see "DHCP Bindings". You can configure MAC address and IP address mapping manually.
Make sure the "Identifier" is Hardware address
and "Type" is IEEE 802.
HTH,
jerry
120
