how to make a route feasible successor
Hi all, I have 2 switches connected , by 2 different l3 interfaces, so they are both successors and load balancing, how would I make one of the routes to become feasible successor? the interfaces are normal fastethernet.
cheers
Carl
Hall of Fame Super Silver
Re: how to make a route feasible successor
Hello Carl,
if you want to make one link less preferred then the other one
check current delay with
sh int fx/y
then use
int fx/y
delay xxx
use a greater value then the default one.
method2:
more selective using offset-list applied under router eigrp process
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_cfg_eigrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1054179
using this you can make one path less preferred only for specific route(s)
Hope to help
Giuseppe
how would I make it feasible successor? i changed the delay to higher, but its still showing as successor.
any ideas ?
Hello Carl,
may you post
sh ip eigrp topology
! let me use placeholders names for the
! two lan interfaces
sh int f0/0
sh int f0/1
sh ip eigrp int f0/0
sh ip eigrp int f0/1
all of these commands on the local router that sees the two equal cost paths
Hope to help
Giuseppe
192
