07-03-2013 07:02 PM - edited 03-07-2019 02:13 PM
Hi Guys,
Someone here tried to make a cross cable (DCE/DTE) from 2 male V35? I need it for my home lab since price of cross cable here is still pricey.
Thank you guys.
Ron
Solved! Go to Solution.
07-13-2013 03:44 AM
Ron,
Making your own "serial crossover cables" is almost impossible in amateur conditions. While the pinouts of individual signals are known, e.g. here:
http://www.cisco.com/en/US/docs/routers/access/hardware/notes/marcabl.html#wp41308
the real problem is that inside the Smart Serial plug on your cable, there are local connections inside it (marked as J1-22 through J1-24 in the pinout above) that most probably connect these pins to the signal ground to indicate to the (H)WIC card what kind of cable is connected to it. As these connections are located in the plug itself (which is often sealed in plastic or in rubber), you will most probably not be capable of modifying them. Even if you cut the cables and crossed the Tx and Rx pairs, the plug would still be hardwired to signal the V.35 DTE mode.
Best regards,
Peter
07-04-2013 01:50 PM
DTE/DCE cable is not expensive
Have a look:
07-04-2013 10:13 PM
Hi Sir,
Thank you for the info but in Philippines cable cost around $35.
I have 4 X V35 & trying to use it if possible to save cost .
Thanks.
07-09-2013 07:26 PM
Anyone please help.
Thanks.
07-09-2013 07:58 PM
You have been given the correct answer above already.
07-13-2013 03:44 AM
Ron,
Best regards,
Peter
08-27-2014 06:25 PM
Hello! My name is Alberto, I'm from Brazil. I managed to make the wonderful cable dce / dte back to back with two cables v.35, but I got a lot of work if you want instructions, send email to me albertosilvah@hotmail.com who teach will soon be posting one video on youtube showing the pinout and cable fabrication.
08-27-2014 06:24 PM
