how to make NAT working in a router with two ISPs ?
nlariguet
10.10.1.0 is my internal network which I want grant access to the internet
(IntraNet) 10.10.1.0 ---> 10.10.1.1 (privateRouter) 10.10.2.1 ---> (PIX) ---> 10.10.2.2 (edgeRouter#2) DHCP ---> InterNet
(IntraNet) 10.10.1.0 ---> 10.10.1.1 (privateRouter) 10.10.3.1 ---> (PIX) ---> 10.10.3.2 (edgeRouter#3) DHCP ---> InterNet
10.10.1.0 is the IntraNet
10.10.1.1 is the private router inside interface (one interface only)
10.10.2.1 is the private router outside#2 interface connected to ISP#2 via edgeRouter#2
10.10.3.1 is the private router outside#3 interface connected to ISP#3 via edgeRouter#3
... and for simplicity let's forget the firewall; what I want is:
IntraNet to ISP#2 (via edgeRouter#2) NATed to 10.10.2.1 (private outside#2)
IntraNet to ISP#3 (via edgeRouter#3) NATed to 10.10.3.1 (private outside#3)
and I want both connections to operate simultaneously so I can selectively route traffic to ISP#1 or ISP#2
WITHIN THE PRIVATE ROUTER depending on traffic type or final destination
5 Replies 5
Jon Marshall
"and for simplicity let's forget the firewall; what I want is: ..."
Do you mean the firewalls won't actually be there ?
It makes a difference because routers support PBR but pix firewalls do not so if you want to selectively route traffic the pix firewalls will get in the way - can you confirm ?
Jon
yes, I'm afraid it's there and will stay there
Actually it's there NATing 10.10.1.0 to edgeRouter#1 inside's because I have one ISP only, but since the other ISP got involved I started thinking a NAT scenario on the private router which actually is not doing any kind of NAT.
Although you say the PIX does not support it (I don't know what is PBR); I'll research it :)
PBR = Policy Based routing which allows you to route traffic based on something other than just the destination address which is how packets are normally routed.
You may be able to use the PBR recursive next-hop feature to get round this but that would mean you would need to allow ICMP from the internal router to the edge routers. If you are happy to do that let me know and we can come up with a config. The config would still need testing so no guarantees as yet.
What IOS version is your internal router running, what hardware router is it and what version of software is the pix running.
Jon
I was just reading that, although I was aware of route maps (using them on another non-related setup) I completely forgot it is called PBR.
Current config does not allow to ping outside the firewall.
private routers relevant commands (current):
boot system flash:c1841-advsecurityk9-mz.124-15.T11.bin
PIX515UR relevant commands (current):
boot system flash:/pix804.bin
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside2
icmp deny any outside3
edge routers (both identical) relevant commands (current):
You mean something like tagging the packets on the private router (these for edge#1 and these for edge#2) and then routing them based on the tags regardless of the destination (or source) address right ?
I was researching a bit and got the following:
iOutside2
description going NATed to PIX's inside#2 ... or to edgeRouter#2's inside ... then to ISP#2
ip address 10.10.2.1 255.255.255.0
ip virtual-reassembly
ip nat outside
exit
route-map rmOutside2 permit 10
set ip next-hop 10.10.2.2
exit
ip nat pool poolOutside2 10.10.2.1 ... normal traffic should get NATed to this address
ip nat pool poolOutside2exception1 10.10.2.3 ... with a few exceptions to the following addreess; think some management ports
ip nat pool poolOutside2exception2 10.10.2.4
ip nat pool poolOutside2exception3 10.10.2.5
iOutside3
description going NATed to PIX's inside#3 ... or to edgeRouter#3's inside ... then to ISP#3
ip address 10.10.3.1 255.255.255.0
ip nat outside
exit
route-map rmOutside3 permit 10
set ip next-hop 10.10.3.2
exit
ip nat pool poolOutside2 10.10.3.1 ... normal traffic should get NATed to this address
ip nat pool poolOutside3exception1 10.10.3.3 ... with a few exceptions to the following addreess; think some management ports
ip nat pool poolOutside3exception2 10.10.3.4
ip nat pool poolOutside3exception3 10.10.3.5
iInside
description IntraNet
ip address 10.10.1.0 255.255.255.0
ip policy route-map rmOutside[2|3] ... can choose only one at a time; but something better than nothing to begin with
ip nat inside
exit
... now I need to actually NAT the inside to the outsides:
ip nat inside source list aclNAToutside poolOutside2 overload ... many-to-one NAT
ip nat inside source list aclNAToutside poolOutside3 overload ... many-to-one NAT
ip access-list standard aclNAToutside
permit 10.10.1.0 0.0.0.255
exit
... adding a few exceptions:
ip nat inside source list aclNAToutsideException1 poolOutside2exception1 overload ... many-to-one NAT
ip nat inside source list aclNAToutsideException1 poolOutside3exception1 overload ... many-to-one NAT
ip access-list standard aclNAToutsideException1
permit 10.10.1.X ... eq whatever
exit
... and thus far I came; ip nat only allows standard ACLs so I have no way to add an exception because for this I need an extended one
... any other way ?
ip nat inside source also accepts route-map which in turn accepts match ip address which accepts standard or extended ACLs; should I follow this path ?
... supposing I find a way to use extended ACLs with the nat command and if (a big IF) I can find a way to get the two route maps simultaneously associated with the inside interface the I can place match commands on those route maps to divert traffic as desired without any need to ping the edge routers like in those SLA scenarios which verify the availability of the target routers, because I will only be NATing to the firewall inside interfaces and what come after that is not relevant from the point of view of this private (IntraNet) router am I right ?
