11-18-2013 12:19 PM - edited 03-07-2019 04:39 PM
The idea is to configure the wifi on the C870 router.
So, I have this switch prepared to receive the router on one port with vlan 109.
The router is with c870-advipservicesk9-mz.124-24.T2.bin
The router is connected from f4 to the switch port, but when I try to put the router port on trunk its not accepting the switchport mode trunk
interface FastEthernet4
description secondary-TO_SW
no ip address
duplex auto
speed 100
no cdp enable
interface Vlan109
ip address 192.168.71.4 255.255.255.0
ip default-gateway 192.168.71.1
interface Dot11Radio0
no ip address
encryption vlan 10 mode ciphers tkip
broadcast-key vlan 10 change 45
Any idea?
** the router its not accepting the switchport command once Im inside the interface
Solved! Go to Solution.
11-18-2013 12:50 PM
No it is the subinterface that you should associate with the VLAN (and which you already have associated with the VLAN). You do not need the switchport mode trunk and it does not work on the interface (as you have discovered). You achieved the same result of this command when you configured
interface fastEthernet 4.109
encapsulation dot1Q 109
now what you need to do is to remove interface vlan 109 from the configuration and to configure the IP address under the subinterface.
Rick
11-18-2013 12:37 PM
yeah it wont work because it is a router not a switch. so you just need to tag the dot1q with the correct encapsulation id to your subinterface;
in your example it 109
interface FastEthernet4.109
11-18-2013 12:43 PM
and this is the result.
R(config)#interface fastEthernet 4.109
R(config-subif)#encapsulation dot1
R(config-subif)#encapsulation dot1Q 109
R(config-subif)#exit
R(config)#int fastEthernet 4
R(config-if)#switchport mode trunk
% Invalid input detected at '^' marker.
its the phisical interface that I should associate witht the vlan, right?
11-18-2013 12:49 PM
yeah thats normal. you dont need to run switchport mode nor it will work.
just do no shut on the physical interface. and print "show ip int br"
11-18-2013 12:52 PM
this is what I have
R#sh ip int br
Dot11Radio0 unassigned YES NVRAM reset down
FastEthernet0 unassigned YES unset administratively down down
FastEthernet1 unassigned YES unset administratively down down
FastEthernet2 unassigned YES unset administratively down down
FastEthernet3 unassigned YES unset administratively down down
FastEthernet4 unassigned YES manual up up
FastEthernet4.109 unassigned YES unset up up
Vlan1 unassigned YES NVRAM administratively down down
Vlan109 192.168.71.4 YES manual up down
11-18-2013 12:55 PM
apply the ip address under the sub interface
so '
no int vlan 109
int f4/109
11-18-2013 12:50 PM
Rick
11-18-2013 01:56 PM
nice!
can reach the default gateway already,
can see the router on the switch arp
but can't go outside
Will check further on the switch and find why
11-18-2013 02:07 PM
see if you have a reverse route from the outside router to R
11-18-2013 02:10 PM
can see the ip configured on the router, but can't ping it.
The switch port interface config:
interface FastEthernet0/19
description ToWifiRouter
switchport trunk allowed vlan 109
11-18-2013 02:13 PM
i presume the other side is a switch
what is the below results;
sh ip int br | ex unas
sh span vlan 109
sh int trun
sh ip protocol
sh ip route
11-19-2013 01:10 PM
great,
After this, issued a no ip route followed by default gateway x.x.x.x and can go out now
