how to query output queue drops on a 3500xl via snmp
I believe Cisco refers to
output queue drops as
"output buffer failures"
On a 3500xl running 12.0(5)WC13
"show interfaces"
FastEthernet0/1 is up, line protocol is up
7490 output buffer failures, 0 output buffers swapped out
But a walk of ifOutDiscards on the same switch shows all zeroes...
IF-MIB::ifOutDiscards.1 = Counter32: 0
IF-MIB::ifOutDiscards.2 = Counter32: 0
Is there a way to query the output
buffer failures via snmp ?
Re: how to query output queue drops on a 3500xl via snmp
Try to use locIfOutputQueueDrops from OLD-CISCO-INTERFACES-MIB.
If it doesn't help check this link
ftp://ftp-sj.cisco.com/pub/mibs/supportlists/wsc3500xl/wsc3500xl-supportlist.html
You can find all MIBs supported by 3500XL there.
//Mikhail Galiulin
That shows all zeroes too...
OLD-CISCO-INTERFACES-MIB::locIfOutputQueueDrops.1 = INTEGER: 0
OLD-CISCO-INTERFACES-MIB::locIfOutputQueueDrops.2 = INTEGER: 0
OLD-CISCO-INTERFACES-MIB::locIfOutputQueueDrops.3 = INTEGER: 0
I will peruse the 3500XL supported mibs. Thanks.
303
